Using large C clamps, I had to remove a couple of clecoes to make this work.
You really need to tighten those C clamps and removed that gap.
Once both sides are tight and you verify the no gap with a mirror, drill away. There are two holes on the fore and aft that you can't get at while the seat back support assembly is on the aircraft.
